Originally Posted by
turnnburn
My question regarding Behotec engines is in regards to their thrust claims. On most if not all of their engines they report thrust figures considerably higher than any other manufacturers for a similar sized engine. For instance Jet Central Rabbit, Jetcat 100, Wren100 are all the same physical size (more or less) as the Behotec 100. The three engines I mentioned all quote nearly identical max thrust (22lbs) give or take. The Behotec 100 claims 28lbs if I am recalling correctly. While I would love to have an engine that is this small physically that produces 30% more thrust than the others in its class I can't help but but a little skeptical.
Why don't you pass by our shop in Houston and have a look at it by yourself.
We also have lots of customers in Texas using the BF-100 with 100% success.
In terms of power-to-weight-to-price ratio it is also one of the best engine on the market:
http://www.ultimate-jets.net/blogs/j...ur-application
