I also agree with the tank or fuel tubing being your issue, but here is another item to check. Since your using the stock muffler make sure that it is not pushed in to far on the outlet tube as that can cut back exhaust flow and cause issues in itself. Also with the G series 90 that engine is not an RPM maker like the S&K Series was, prop it for around 11.5 and it will stay happy.
