RCU Forums - View Single Post - Need A COX .051 W/ throttle
Old 03-12-2014, 06:22 PM
John_M_
John_M_'s Avatar
Was it a Hiscott?... try Ebay, definitely going to be a hard one to come by... I had a T/D 051 with a rotating throttle collar on the exhaust ports, worked a treat until the collar and cylinder head wore; too much leakage and wouldn't produce enough back pressure to throttle down... the carb / muffler combo is the way to go... I just luv'd my 1/2A days.
INFO:
http://www.mh-aerotools.de/airfoils/cox_3rdparty.htm
http://www.mh-aerotools.de/airfoils/...e%20Dee%20.051
http://www.ebay.com/itm/Cox-049-05-0...-/271033533403
The Cox Cat #201 Tee Dee 05 RC was actually an 051 and came out Nov 1994. These have a special cylinder which has the same porting as the Tee Dee 051 but "no" SPI (Only 2000 were made)
You definitely need the Tee Dee 05 05 RC with-out sub piston induction !!
John M,
