Originally Posted by
flyinwalenda
The arming switch installs between the battery pack and the ESC like in the diagram below(disregard the BEC connection and clipping the red wire if you don't have a BEC)
Here is an ESC with a switch
That would require quite a bit of complicated soldering. I think I will need to continue with the unplugging of the battery pack. Why can't anyone invent a switch harness for an electric plane?
