Originally Posted by
flyinwalenda
Arming switches are typically used on medium and larger planes using higher amperage set-ups. You would have to make an arming switch with JST plugs and connectors, or install an ESC that has a slide switch.
Not sure where to get a ESC that has a slide switch. You said in a post above that this would not stop the battery pack from draining, which kinda defeats the purpose of having the power switch. And constructing an arming switch with JST plugs would be too complicated for someone with basically no soldering skills. So I will have to keep going as I have been with unplugging the battery pack. Thank you for your help.
