Need more information.... are you using a Y connector to drive both servos or are they plugged into different channels on the receiver? Is the 'waving' a very rapid movement, or is it slower, more gradual movement? What is your power source for receiver and servos? Radio? Have you tried switching the two ailerons connection (ie plug left aileron servo into right aileron port and vice versa) to see if the problem stays with the right aileron or moves to the left aileron?
Detailed information helps people provide better/quicker suggestions for fixes.
Woodie
Reason: typo
