Ok wooden dowels are a problem then. Back to square one. What can I use to move the engine out to keep from adding a lot of lead weight? I have both ignition and receiver batteries in the fuel compartment. What about building a box around the dowels epoxied, to were I can epoxy weights into it that would add support to the dowels like an engine box you see on other airplanes
