RCU Forums - View Single Post - GP f4 Phantom
Old 10-02-2003 | 07:16 PM
kirknik
Default RE: GP f4 Phantom
Hey Balsa.
I agree, the Phantom is flat out the coolest, wickedest and best looking jet ever. I built one last winter. All I can say is'build light' Mine had completly sheeted wings and robart retracts. covered in silkspan and dope. Weight was around 13 lbs. I had an OS FX .91 in it and it was just good enough. More power would even be better. This plane must have been awful with a .60.
Looked great in the air but landings were very fast.
The fit of the plastic nacelles and canopy were brutal.
Also watch out for nose heavy. I had nearly a pound of lead in the tail to balance it. Put your batteries in the very back, tail cone if possible.
Might consider a pump as well as the engine is a long way from the fuel tank.
Good luck., if this works picts to follow......
ID:	65197   Click image for larger version
ID:	65198   Click image for larger version
ID:	65199   Click image for larger version
