RCU Forums - View Single Post - Flanged bearinngs on HL gearboxes?
Old 04-07-2014, 12:56 PM
dyeager535
For size not sure. Wonder if some nylon washers could be used, they would provide less friction than steel on steel.
Nylon would be pretty easy to cut/drill to desired ID though. Finding proper thickness might be a different story.
Can't believe more aren't jumping in with suggestions...I'm curious as well, reasonably priced bearings for the gearbox shafts were on my to-do list as well. Then again, the gears themselves exhibit considerable slop on the shaft anyway.
