RCU Forums - View Single Post - Telemaster kit v-2 conversion
Old 04-13-2014 | 08:07 AM
raj92
Originally Posted by buzzard bait
Oh you have a throttle...great! I always just flew mine flat out. So you'll need a third servo. Micro servos will work fine for everything including throttle. I'd use 1/2oz servos all around. The throttle linkage for those is usually just a thin piece of music wire.
Don't get carried away beefing it up just because it has a glow engine. Even in the old days RC models with Pee Wee power only weighed 6-7 ozs. The engine really doesn't stress it much. The 1/4 inch stock I recommended is actually overkill. You could use 1/8 inch. The main thing is fuel proofing, not beefing up.
You're plane should weigh about the same with a Pee Wee as it would with electric power. The battery for Rx and servos can be very light. The engine is very light. No worries.
Jim
thank you so very much jim as soon as iam done with my college exams i'll start working on this i will take the liberty to PM you if and when i get stuck only if you are okey with the botheration
Raj
