I didn't understand the Function command as well as I thought. I don't see how to assign two channels to Aileron2. When you go into Function, Aileron2 shows as having Null for both the command control and the trim. It's obviously assigned to work from the Ailleron stick and trim by the Model Type command. I can see how I make Aux5 work with Aileron1 by assigning the command control and trim to it the same as Aileron1 but how do I do the same for Aux4 when the channel I want to mate it to is Null and Null?
If I assign it to the same controls as Ailron1 then the differential won't work.
I'm sure this will become easy after a few thousand hours programming but at the moment I'm stumped!
Malcolm
