Sorry I didn't include these details earlier.
The LiPo is a 4s Turnigy Nano-Tech 5000mAh 65-130C. The ESC is HobbyWing XeRun 150a. The motor is a Turnigy Trackstar 2350kv, it is a sensored motor however the sensor is either damaged or the port is where the censored wires goes in to the ESC and so it's running without it instead. The can length is 68mm and the diameter is 42mm.
I haven't checked the bearings to be honest however I did buy a whole front end of the car which claimed it had new shock oils, serviced diff and it looks fairly decent. I have put all new gears, gaskets, and oil in the centre and rear diff myself.
I just wanted to clarify my earlier concern about the car not responding, was it actually the battery running out of juice then or something else?
Thanks.
