mate you do need a bigger workshop. that is a big plane.
You need more warbirds, enough of the wannabe helis hehe
Tiggy flew again. Engine seems ok at top end though still not completely happy with low end. I raised the LE of the stab to try and cure the climbing under high throttle. It actually made it worse and it climbed out at 45 degrees. As the LE of the Stab also has brackets what I did by raising it 2 egress was to make an upside down airfoil section. so low pressure on the bottom forced the tail down and made the damn thing climb!
I will use a throttle to elevator mix to cure it I think.
No progress on the 47, perhaps tonight. Did not get home till 6.30 last night as had to get physio on my knee, medial ligament playing up. Ouch.
Got Bundaberg Warbirds coming up weekend of the 6th so might head up there for the weekend. Mustang and maybe little spit if I can squeeze it in the car.
Bob get that bloody road sign / voting sign flying!! Vote for Bob, you can trust him to spend your tax dollars on model planes!! Works for me. Better then the idiot you have in charge now anyway. haha
