Originally Posted by
pcarluvr
We used to save the plastic "tree's" from the parts that came in kits. If you stripped a hole, you'd cut a length of the tree off, drill a bigger hole, glue or epoxy it in, drill new screw hole. It worked very well because you were using the same plastic the part was made from.
