Couldn't find the cowbell so I settled for lightning bolts and arrows. Couldn't find my videographer for the taxi test so I took some pics. Sorta looks British... Oh well that's what happens when covering with scrap and no plan. I think I'm going to give an 8X6X3 as the 9X6 is whacking the ground when I hit small bumps in the road. I didn't mind tearing up the $.99 MA prop but those Slim Props are close to $10.00 apiece now days. The other issue with the Slim prop is the 8mm prop shaft hole the adaptor from the original power set up is unnecessarily heavy. 4mm to 8mm is an odd ball adaptor and will require taller wheels to run a 9" prop
