@bigmd74
Have you tried checking the battery voltage with a volt meter? I'm curious what the actual voltage of the battery is, not what the 965 is currently reading. Also, are you using any home made adapters with your battery? If so, you may want to check the connector for cold solder joints. You may e-mail me at
[email protected] should you wish to converse privately about this matter.
John @ MRC
