I give up! couple last comments
i forgot to say earlier, my bad, is that the ring is normal for the 2mm stroker crank, it sits 1mm lower than stock at bdc as the crank pin sits 1mm further away from the crank centre, it also sits 1mm higher at tdc and the hhead is machined to accomadate that, 1mm stroker would be .5mm higher and stock crank your'll barely see the ring. so as i said before it's normal and nothing to worry about.
