RCU Forums - View Single Post - 1/4 turn on high speed Saito 1.20 makes engine quit ?
Old 06-20-2014, 10:58 AM
jeffEE
jeffEE's Avatar
So just how new is this Saito? If you have less than a gallon of fuel run thru it, you should NOT be at the point where you need to tach it at High RPM. You should still be running it rich. And I agree with the 2 clicks at a time. Good luck.
