RCU Forums - View Single Post - Fei Bao Jets Dolphin build thread by RCISFUN
Thread
06-23-2014, 06:42 PM
1
RCISFUN
My Feedback: (
44
This will be my build thread for the new Fei Bao Sport jet, the Dolphin
In this thread I will attempt to cover the building sequence and the design of internal mounting components that I made during the assembly of this great model.
Additionally I have been asked by the factory to write the manual.
I starting working on this model in the beginning of May for a couple of evenings a week and have been photo documenting my work as I proceeded. I designed all of the internal mounting parts in AutoCAD and have forwarded to the factory for inclusion into the production model.
Drawings will include fuel tank mountings, two nose mounted battery boxes, UAT mounting, mounting plates for servo connections and a balancing fixture.
I will start off with photos of the completed model, specification of the various parts and then start posting my build sequence.
The model has just been test flow by three competitive pattern pilots, Jim Hiller, Lewis Patton and Joe Stek. The feedback from these three gentlemen was unanimous, FB Jets has a winner on their hands.
The basic specifications are as follows:
Length: 104 1/3" (2650MM)
Wingspan: 91 3/4" (2330MM)
Dry Weight w/all components: 35 Lbs (15.9 Kg)
Power: 32 Lbs to 40 Lbs (140 N to 180 N) Jet Central Rhino used in prototype
Fuel Capacity: 155 oz (4.6L) (Prototype)
Main Wheel Diameter: 4.3” (109 mm)
Main Strut Length: 7.5” (190.5 mm)
Pipe Length: 37” (940 mm)
Pipe Diameter: 3 ½” (89 mm)
Bell Mouth Length: 2.75” (70 mm)
Equipment Used:
Elevators (2) Hi-Tec HS-7955TG
Ailerons (2) Hi-Tec HS-5625
Rudder Hi-Tec HS-7955TG
Flaps (2) Hi-Tec HS-7955TG
Steering Hi-Tec HS-645MG
Door Valve: Jet Central Dual Action
Landing Gear Valve : Jet Central Dual Action
Brake Valve: Jet Central Single Action
Door Sequencer: Jet Central
ECU Battery: 5000 mAh LiPo 2 cell Hard Pack
Receiver Battery: 5000 mAh LiPo 2 cell Hard Pack regulated to 6V w/Liner voltage regulator
06:44 PM
Reply
Like
RCISFUN
View Public Profile
Send a private message to RCISFUN
Find More Posts by RCISFUN
View iTrader Profile
