RCU Forums - View Single Post - Closed Loop (Pull-Pull) Questions
Old 10-06-2003 | 04:12 PM
Flypaper 2
Default RE: Closed Loop (Pull-Pull) Questions
Steve:
Less than the tiller arm. When you give rudder, one side will go slack but the rudder has a load on it, so it wont hurt anything. When you go back to neutral, they will tighten up again. If you want, you could drill the servo arm.
