RCU Forums - View Single Post - Savage x f4.6 cutting off after WOT
Old 07-23-2014, 06:35 PM
-SomeGuy-
-SomeGuy-'s Avatar
If its dying as you're giving it wot then HSN is to lean. If its dying after you let go of WOT then its rich with idle set to low. Factory settings are on the rich side but all to often they come from the factory way way to rich. A friend on mine had to turn in his LSN 4.5 turns just to keep the engine running, no amount of idle gap helped.
