Tom,
yes mate get into it, get some documentation together and enjoy!
Glenn,
P51 still has some minor repairs to be done to the cown chin with new layup with it goes over the curved area and a split in it. Not a biggie.
some work in the cockpit where some of the scale fitting came loose, again not a biggie.
Wing is repaired, just have to finish the filling and sand back then shoot some primer, do panel lines on repaired area, small amount of rivets then top colour and touch up the stars/bars under the wing.
P47 needs some reinforcing of the retract rails with CF and epoxy, might even make an alloy doubler. not sure yet.
Then dummy antenna mounting point.
Cowl mounts to be completed.
small amount of filling and primer to hanger rash areas.
Paint the cammo scheme, stars/bars and nomecleature, systems fit out and test runs prior to test flight. Has been at this stage for about 2 1/2 years
cheers
P
