RCU Forums - View Single Post - Buddy cord between 14mz and 18mz
Old 08-15-2014, 06:26 AM
Bax
Per the chart in the 18MZ manual, you need to use this trainer cord:
FUTM4405 MM-TC-FG 12FG TRAINER CORD US$44.99
We'd not know why the wireless system would not work. You do have to have the student's transmitter set to PPM and using a 2.4 GHz module. The module must be set to 7-channel mode if you're using the TM-8 module. Or you can be using a TM-7 module.
If you're using the 14MZ as the master transmitter, then you must set the 18MZ to 7-channel mode.
