Banzai Hobby is now Taking Pre-Orders on the OVERDOSE Divall Chassis Kit
Second RC Drift Shaft Drive Chassis released from OVERDOSE, named Divall!!
Using Center Motor & Center Battery lay out with shaft drive chassis.
Front and rear center drive shaft turned opposite direction in order to prevent reversed torque. Innovative idea and downside of shaft drive chassis is no longer!! As many people like direct drive feel of RC drift chassis but used to compromise the handling. With OVERDOSE Divall, you can enjoy both shaft driven chassis direct drive feeling as well as perfect balanced handling like belt driven chassis.
Using OVERDOSE innovative Bevel Gear lay out in order to minimize reversed torque and perfect balance. Bevel gears are made out of steel.
Using, Front Ball Diff. and Rear Rigid. Gear Ratio: Front 40T/15T, Rear 38T/19T. F&R Ratio is 1.3
Newly designed F&R Gear Case. F&R Upper Bulkhead using aluminum.
OVERDOSE
Divall Chassis Kit (Purple)
OVERDOSE
Divall Chassis Kit (Red)
This is PRE-ORDER
If you place pre-order, we will do our best to secure your products for you and ship them to you as soon as we receive them in stock.
If you make a pre-order, as usual, we will throw in goodies for you
Get in quick and don't miss this opportunity as only limited quantity is available.
ETA: End of September 2014. This may change without any notice by manufacturer.
