RCU Forums - View Single Post - Savage x f4.6 cutting off after WOT
Old 08-18-2014, 02:59 AM
supertib
supertib's Avatar
the idle needle should be the needle you touch first when you retune day to day...when someone says you set it once then leave it they are very wrong.... idle gap is not something that can be preset to one setting...idle gap needs to be adjusted according to the amount of available 02 in the atmosphere........many times when the climate changes all that is needed is a slight change of idle gap, many people make the mistake of adjusting mixture needles first.....
