RCU Forums - View Single Post - Help on Throttle Cut setup
Old 10-07-2003 | 08:55 PM
randy41
Default RE: Help on Throttle Cut setup
You need to go into the the throttle cut settings and put
the throttle stick % to 0. And why your there make sure the switch
position is the way you want it. Up is engine off and down is engine
on is the way i got mine. I think whats happen is you got the
throttle stick to cut the engine off also. I think the default setting
is 5 % of the throttle stick is were the engine will shutt off. Make
that 5% --------> 0%
