Originally Posted by
2walla
I have run deans on setups that pull 100 amps with no problems. I use power poles on smaller setups. Usually under 30 amps. They tend to wear out and and i have had a couple develop bad connections over time. I am moving from andersons to xt60 connectors as they show up on a lot of batteries.
If you are going to standardize on XT60's, you can even use them for your arming plug with this housing adapter:
https://www.hobbyking.com/hobbyking/...dproduct=54804
