RCU Forums - View Single Post - pros and cons of sensored vrs sensorless on a 1/10 summit
Old 09-09-2014, 03:41 AM
tictactics
Default pros and cons of sensored vrs sensorless on a 1/10 summit
ok,still kinda a noob on the technical side of things. so when in doubt, rely on experienced people.
set up is a bone stock summit 1/10.
current spur is 65t
stock diffs- i want to retain the T-lock feature
tires have been upgraded to the TRENCHERS
tossing up between a CC 2200kv/MM set up, or the ever popular RX8 set up.
mostly will be used for loose dirt bashing,but a good bit of rock crawling..........
experience with my E Revo says the CC set up will be glitchy and jumpy when trying to crawl.
if swap to a tekin set up,will that affect transmitter,reciever set up?
any help will be greatly appreciated............. never dealt with a sensored set up before
