RE: Closed Loop (Pull-Pull) Questions
I understand your explanation; but since the bellcrank must be supported by a platform, and running the elevator pushrod "under" said platform would restrict accessibility, I arrange my set-up so that the elevator servo sits higher, with the elevator pushrod "over" the rudder control system (lower, when the plane is right side up).
Steve
