Originally Posted by
SrTelemaster150
You show me an air cooled, carbureted, 12:1 compression ratio 4-stroke engine, running on pump gas & I'll show you an engine that will detonate under load once it gets to operating temperature.
10.5:1 can be streetable IF the right cam specs keep cylinder pressure down until the revs climb. 12:1 in an air cooled engine W/O computer controlled electronic fuel injection & ignition on pump gas is just waiting to hammer the piston crowns.
what if he's using low/no nitro and a super cold glowplug? theoretically speaking.
