The stickers came from HK
https://www.hobbyking.com/hobbyking/...al_Sheets.html
I'm thinking that the bird beak would go better with the cargo plane look verses the single man bubble windscreen. I cut a 1/4 inch off the bottom of the foam cargo plane cockpit, it looks much better. I plan on using yellow trim similar to the Blue Angels scheme, My other CX250 has a colorful scheme that ultimately adds to loosing orientation. It's translucent film on the wings makes it look like it is in a different position at times, than it really is. It is small and fast enough that keeping track of were it's at is best done by memory not visual orientation if the frame is at much distance. So, I make lots of turns and keep it close.
