RCU Forums - View Single Post - OVERDOSE Divall Chassis Kit [PRE-ORDER]
Old 09-29-2014, 01:47 AM
banzaihobby
Divall Front One-Way Set in Black
Divall is off for the front one-way unit. By replacing the front ball diff of standard kit, drift control performance will improve to achieve a quick steering response. Adopt φ6mm one-way clutch of large capacity, we have succeeded in both of the goodness of cut and high durability also adhered to the dimensions of the press at the time. Standard equipped with a one-way adjustable cup joint OD unique, it can slide to a maximum 2mm outside the cup joint by a spacer further. Can be addressed without changing the length of the drive shaft even if you change the camber and tread.
***Bevel gear is not included in this product.**
Please Check us out on Facebook for Weekly updates and Specials
Banzai Hobby Team
