[QUOTE=Greg Wright;11890379]
Originally Posted by
CaptRKO
Quick question.....
Any of you guys have a small space or gap on the front wing saddle where the wing goes into the forward fuse? I have about 5mm and I can see the carbon dowels going into the holes in the fuse. Is this normal? I know there is no way to adjust this.....wondering what you all have in the way of a gap?
Greg can you post a closer shot of your gap? Here is what I have.......
If you look at the side view picture i posted. Post #1076 it appears as if i have the same gap.
I'm not to worried about it as this is a mass produced ARF not a self built project. If i had built it then i would be a little more critical about the fit of everything.
It is about 5mm.......not sure if it really matters but want to be on the safe side
