RCU Forums - View Single Post - DX9 mix programming
Old 10-06-2014, 07:19 AM
  #31
AndyKunz
SPM is the file type you get when you Export a model. How-to is in the manual.
What does your ignition require for a signal in order to arm it? Have you installed the latest update of the AirWare (from May)?
What have you done so far? Are you using a mix (like the subject suggests) or are you using the Digital Switch Setup screen (the purpose of the function is to define switch positions)?
I'm happy to help, just need a little information. The SPM file will answer those questions.
Andy
