Originally Posted by
jetmech05
Jester you are correct. I believe you should learn to fly...4 channels, no mixes, no expo.
basic flying.....in the end you'll be a better pilot.
I can't agree with that. I do think that a beginner should advance to a 4 channel airplane quickly if they start out on 3 channels. Why would you want to make the learning process more difficult? The airplane should be set up as any other airplane and that is to make,it as easy to fly as possible. Would either of you guys set up a pattern airplane to be more difficult to fly because in theory " it makes you a better pilot "? Regardless of beginner or pro, use every tool available to make the airplane fly better/easier.
