Originally Posted by
duty
have you ever heard or tried the perry carbs ?
Never tried one, probably never will. The smallest debris particle fouls up the mixture. They are prone to o-ring shrinkage more than other carbs which makes them impossible to adjust properly when that happens. If one understands how to adjust a Perry carb properly and has a clean carb with good o-rings, they work very well based on what others have said about them. I much prefer the Italian ST 2-needle carbs - they work fantastically as long as you adjust them properly. They get setup slightly differently than other standard 2-needle carbs l.
I will not own and run any of the Chinese SuperTigre engines - I only have interest in the Italian made engines and parts. If you have an Italian ST engine, the fitment of the Chinese parts is not always the same. Many parts will not interchange between Chinese made and Italian made engines of the same model.
