RCU Forums - View Single Post - EME Starter for the DLE111
Old 10-23-2014, 06:35 AM
gsmith6879
My Feedback: (37)
Originally Posted by rampage-1
I was just guessing that you needed a puller. I read no manual comes with the starter. But from looking at the pictures on how it's made, it did not look to bad on the install. I guess you have to re-time the motor. I have two manuals on the DLE111 one has no info on timing and the other says timing is to be set at 40degrees. I would guess timing would be more like 28 to 30 degrees.
To bad you did not make a u-tube on the install, you would be a hero do to no manual.
I did not have to re-time my DLE111 after the installation. Everything is keyed and the quality of the starter parts pretty much locks everything where it needs to be. I did mine and then a freinds and they both ran great after the installation without any adjustments.
