The manual calls for the CG to be 2 1/4", not 2 1/2" so you may have balanced slightly tail heavy to begin with. Also, changing battery sizes will affect the CG. Did you balance the plane with the retracts down or up? It should be balanced with the gear up as they retract backwards and will make the plane tail heavy if you don't.
