Agreed, but with a twist: If it's doing it without your input, then there's no need to flip the direction until you can assure it's not just bad adjustments. Set throttle trim to dead center (0), then recalibrate your esc. THEN, if it goes backwards when you push forward, flip the setting or reverse the motor wires. No need to be flip flopping anything if that's not the issue
