Originally Posted by
BobHH
Ha Andrew, Brian!! That's the one!! Anyone got a scan of the plans that I could use to build one??
Bob
Bob -
This is the best I have -- it's a .jpg, but you may be able to pull sufficient dimensions from it to cobble up a set of builder's plans. There is a scale, so you will be able to get at least a base measurement.
Edit: I've added a PDF converted from the .jpg . That may help in blowing the plan up to a workable size, at least so you can get a decent set of drawings.
