Engine mount rails are 8 inches with the pivot point of the tumble tube slightly less that 7 1/2 inches.
I test fit my turbine and pipe. My pipe does not need modification. It was manufactured to the right size (length).
Did you have to make the shims to center the turbine with the tumble tube or did they come with the kit. I didn't check.
