It won't bounce or porpoise on landing if you use crow braking, over 60degs of flap (air-brake) and 7/9mm up aileron, the reflex on the ailerons reduce lift and help prevent the tips of the wings stalling before the root, due to the reduction in lift the landings will be shorter and help prevent bounce or porpoising, unless you land it on the nose wheel first that is.
Mike
