Originally Posted by
arcdude
Now that it's been snowing for the last couple of days and for the next week everyday with -10 degree temps it's time to hang up the boat until spring and get working on this project to have something to play with. Anyone that runs on snow I could use a little input as to the basic set up rudders 1 or 2 height and so on and whether they should extend out beyond the transom or not would be most helpful. In order to adjust the CG should the motor pod be separate from the rudder assembly for ease of adjustment? Thanks
Use whatever set up you have for the water. Nothing special is needed. I would however, recommend a servo saver on the rudder servo. When you blowover, the rudders generally take the brunt, so protect them if you can.
