RCU Forums - View Single Post - G&L 1/5 DHC chipmunk - diary of a build.
Old 11-17-2014, 12:06 PM
  #944
acerc
acerc's Avatar
Those look to be where particles were on the surface and the primer was sprayed to heavy, when both of those come together it creates what appears to be small air pockets that burst. Next go around make sure to tack rag it a second or two prior to spraying, use 30-35lbs pressure, and you may even need to thin the primer a tad.
