RCU Forums - View Single Post - G&L 1/5 DHC chipmunk - diary of a build.
Old 11-17-2014, 04:15 PM
  #946
TonyBuilder
TonyBuilder's Avatar
My primer went on smooth as silk. I do three or four thin coats. 15 psi is not enough pressure I would think. The primer/ paint dries fast so do a test piece and if it looks good go for it. The results should be present on your test piece immediately so just play with the pressure/ gun. Also you should be thinning the primer/ paint.
TB
