Originally Posted by
jsanchez581
Everyone talks how good is the klass kote paint and I don't doubt it. I don't know what I am doing wrong, but his is the result that I am getting (this is primer, but also had the same thing with colors).. can you please tell me wants is the issue (look at the picture to see the "dots")?
Those look more like solvent pops or expanding air pockets in the substrate under the finish caused by an elevated temperature change to early during the primer cure or dry cycle, did you spray in ascending temperatures, or in the sun, or move your item from the place you sprayed into a much warmer area?
Bob
