Originally Posted by
Bozarth
Just put some outer pushrod tubing in your fuselage and let the cables run through it. Any small tube (antenna tube, Gold'n'Rod housing, etc) will work.Kurt
+1 I have done this several times. The hard part is getting the geometry correct so one cable does not go slack.
