Old 12-20-2014, 08:23 AM
1mtx1
I was in the same boat i found a used team assocated 18mt that is stock but the last owner put on dean connectors . I like the idea as i am kinda up in the air about going brushless so the stock brushed these trucks come with will do just fine. My issue was the charger and the batteries . I see these 100.00 rtr out there come with 4-10 hour wall charger that will not get it done or less you buy a better charger . Keep in mind most of these micro esc's are set up with micro ends so you will need a micro end battery and a better charger. I like the newer rtr to be honest just for the water proof and part support . I would keep in mind of the charger/battery issue or maybe non issue
