RCU Forums - View Single Post - 1/8 scale TopFlite Corsair Mods
Old 12-22-2014, 06:04 AM
  #1554
acdii
Finally getting back to mine. Got the Fuse assembled and ready for paint, then moved on to the wing, filling, sanding, and almost ready for filler coat of primer for a final wet sand. I checked the white paint I had made and looks like a perfect match, not too white, with a touch of blue/grey to it. Still have some final fitting to do for the flaps and ailerons too before gluing them in. Not going to work on the gear and tail doors until after I have the plane done and some flights on it. Once I see how it handles on the ground and landing, then I will have a better idea on if I should make them or not. Since I fly off grass, they could be easily ripped off.
ID:	2056943   Click image for larger version
ID:	2056944   Click image for larger version
