[TABLE]
[TR]
[TD="bgcolor: #f0f0f0"]FEATURES[/TD]
[/TR]
[/TABLE]
For use with O.S. GG series gasoline powered engines that use a
glow plug instead of a spark plug for ignition
Specifically designed for a gasoline/oil mixture
Uses standard glow igniter. The plug will be out in late December I believe it can be used with 30-50 to 1 mix Tower hobbies is showing the engine and the parts list under OS gas engines
